496 mag sea pump hose sizes >
Old 06-13-2016 | 02:58 PM
Default 496 mag sea pump hose sizes
There are 2 different hose nipples on the back of the Merc 496 Mag Sea Pump (Serpentine Belt Drive), can anybody tell me what those 2 different hose ID's are ?
90profx is offline
Old 06-13-2016 | 06:15 PM
both 1.250,at least that is what 454 and 502 engines use.
mike tkach is offline
Old 06-13-2016 | 07:23 PM
Definitely 2 different sizes.
underpsi68 is offline
Old 06-13-2016 | 08:21 PM
Think the outlet is 1 1/4" and inlet is 1"
getrdunn is offline
Old 06-14-2016 | 05:29 AM
I, like a dummy for got to measure the hose ID's when I just rebuilt my Sea Pump, the back plate nipples are 2 different sizes for sure. The large one is 1 1/4" ID, that I'm pretty sure of, it's the smaller one I'm not sure of. I really need to know for sure as I'm installing a Sea Strainer and want to order some new hose up front before I start the install to reduce any down time.
Thank you
90profx is offline
Old 06-21-2016 | 05:00 AM
Anybody got some sizes for this please ????????????????????????
90profx is offline
Old 07-05-2016 | 12:41 PM
Yep. The inlet (which is the top nipple) takes a 1 1/4 inch ID hose.
The outlet (bottom nipple) takes a 1 1/2 inch ID hose.
This is correct for a sea pump that has a rear cover that is separate from the pneumatic water dump valve. I am not sure if that still holds for the integrated cover/valve or not.
BajaDan is offline
Old 07-05-2016 | 01:24 PM
Thank you very much for posting this up, greatly appreciate it.
90profx is offline
