Correct spark plugs and wires for '94 Mercruiser 454?
I haven't used their but I here they are good.
The coil wire boot fitment is typicall for most wire sets, as the wire depth (where it pushes in and 'clicks' into coil vs boot can be off a little. Sometimes, dielectric grease can make the boot push away from coil.
If the fit isn't good, I'll schooch the boot up the wire some so I can push wire into coil till it 'clicks' and then I'll hold wire and will other hand gently push boot down onto coil tower.
I actually use a MSD coil wire retainer on boats that are run hard in the rough because I've had just a couple pop off in my lifetime.
Ayuh,.... I guess I shoulda prefaced that with, "Generally speakin',".....
