cmi header install
Old 07-30-2016 | 10:49 PM
Default cmi header install
I have a set of cmi fusion headers installed I am having Clarence issues with the water distribution tube and the back of my alternator I am running factory power steering / alternator low mount bracket any
suggestions would be great cmi told me to tweak the water inlet tube I did slightly but don't want to any further. and I am also running rubber distribution tubes
redwavecrash is offline
Old 07-31-2016 | 12:23 AM
Get a different PS/Alt bracket is about the only other solution.
Griff is offline
Old 07-31-2016 | 08:16 AM
i looked at new brackets on cp performance , and Teague but they were both closed yesterday to call and ask questions so i wasn't sure witch one to order they both sell one that is the power steering alternator combo and it say it makes room for power flow manifolds, the Teague is a imco part and cp im sure is a hardin marine part
Old 07-31-2016 | 03:56 PM
have any pics?
sutphen 30 is offline
Old 07-31-2016 | 08:36 PM
post pics tomorrow night just covered the boat for the night.
Old 08-01-2016 | 08:50 PM
[ATTACH=CONFIG]557846[/ATTACH]
Old 08-01-2016 | 11:23 PM
I don't even know how stock manifolds could have worked with where the alternator is.
I had CMI Unitops on my Pantera and have E Tops on my AT and neither were/are even close to that tight. Both used the factory merc PS/Alt bracket.
Griff is offline
Old 08-02-2016 | 05:17 AM
Didn't you have lightnings on that same motor without issues?
class6 is offline
Old 08-02-2016 | 09:29 AM
running stock merc bracket and yes had lighting headers on before no issues with the lightings
Old 08-02-2016 | 11:53 AM
Wow, that's a problem. My hose was snugg but not that snugg. I found that the brass 90* fittings for the pex tubing that can be found at any Home Depot worked for me. I had to splice in 90* fittings to get my tubes to clear.
Baja Rooster is offline
