525 oil leak
Old 07-31-2016 | 10:13 PM
Default 525 oil leak
Just bought the boat this fall and motor hull was drity with little oil cleaned but now I know we have a leak. Motor has 80hrs and I am getting oil leaking in rear of motor somewhere.. I assume it's not main seal cause its not sling everwhere.. Does any one have any experience with what might be leaking or where to start looking..
waynepaul is offline
Old 08-01-2016 | 12:32 AM
Probably an oil cooler line issue.
Griff is offline
Old 08-01-2016 | 01:54 AM
Possibly an intake manifold gasket leak where it meets the block on the rear of engine. Mine only leaked under load.
GLENAMY 242SS is offline
Old 08-01-2016 | 06:38 AM
Make sure it's oil you are seeing. Sounds dumb but leaking water will look like oil too because it has a rusty brown color.
1MOSES1 is offline
Old 08-01-2016 | 06:49 AM
WHAT Is THE Issue With OIL COOLER lines. Is it a loose fitting issue or replace the hose issue
Old 08-01-2016 | 08:11 AM
obnoxus's Avatar
Charter Member #1171
What year is the motor? The early 525's were known for rear main leaks FYI
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-01-2016 | 08:39 AM
Motor is an 2007
Old 08-01-2016 | 10:01 AM
You can buy an oil dye at any auto parts store that works amazingly well. Just pour it in the oil and using any cheap UV flashlight you can see exactly what's going on.
Baja Rooster is offline
Old 08-01-2016 | 01:08 PM
obnoxus's Avatar
OK,,,, they were redesigned by then,,,, not saying that cant be the leak, just alot less likely. I would go to the remote oil filter lines and intake next
obnoxus is offline
