which merc coupler
Old 09-14-2016 | 05:20 PM
Default which merc coupler
I am putting together a 548 bbc engine and will be running a bravo xr with a sportmaster The engine will most likely later be running a supercharger next spring I don't know what drive coupler is supposed to be used. I see there are like 4 different ones.Anybody able to steer me in right direction. Picture and part # would be great. Thanks for any info.
TwoKs is offline
Old 09-15-2016 | 01:16 AM
I would use the steel splined one. It comes in standard or with a long snout.
All the Merc part numbers are listed here
http://www.mercruiserparts.com/bam/s...1368/10772/130
Griff is offline
Old 09-15-2016 | 08:10 AM
Thank's for info Griff.
TwoKs is offline
Old 09-15-2016 | 08:23 AM
F-2 Speedy's Avatar
http://www.ebay.com/itm/New-OEM-MerC...lp6YMg&vxp=mtr
F-2 Speedy is offline
Old 09-15-2016 | 03:03 PM
Thanks 33outlawsst. Any mods if you use long snout? Do they both use same bell housing and CV joint and spilne?
TwoKs is offline
Old 09-15-2016 | 03:32 PM
F-2 Speedy's Avatar
no mod's, just a little tighter getting it in the inner transom assembly, just go in at a little angle down in the back and you'll be fine.
