Removing VST Fuel System - 502 MPI >
Old 10-22-2016 | 08:21 PM
BUP
I am in favor of getting rid of the VST completely - Too many problems years ago. I do not see them anymore coming to me.
Like the Weldon pump and returning the fuel back to the tank - splicing the fuel fill install the return adaptor is what have done in the past for a jist of it.
BUP is offline
Old 10-22-2016 | 08:29 PM
Originally Posted by No Coast
Granny did I read your post right, your looking to supply 900 HP each engine with a modified MPI intake and modified VST pump system??
Originally a 502mpi, want to make sure it runs good before they get pulled. Getting small blocks with blowers that will make750 easy
GrannySShifting is offline
Old 05-07-2017 | 09:33 PM
Check my posts here how I did the a1000 install. You can use any pump that will suffice
http://www.offshoreonly.com/forums/d...p-removal.html
The Ace is offline
Old 06-29-2017 | 09:27 PM
So I had a stalling issues dropping in and out of gear. Took into shop to check computer and I'm being told low fuel pressure. So I went out and ordered new pump, added a efi regulator. So I fired her up in driveway and I'm still only seeing 30 lbs at idle ? Was told I should have 43 . I see it still has a mechanical pump on it. Is this normal? Should I remove that mechanical pump no block that off? my pump wax located on back of block.
Force265 is offline
Old 06-29-2017 | 10:14 PM
SB
Wwhat pump and regulator did you get ? And if aftermarket, how did you install it in the system?
SB is online now
Old 06-29-2017 | 10:47 PM
Regulators are adj, did you run the adj down? it takes little volume to make that pressure at idle, if so your lift pump is likely the issue
Old 06-30-2017 | 07:44 AM
Yes both regulator and pump aftermarket...pump is a Mallory inline 11106m and a phonix efi regulator... out of the bottom side of cool can into pump then pump to reg then fuel rail...return from regulator to fuel filter. I did turn screw in and didn't see any change in pressure.....thanks for the help
Force265 is offline
Old 06-30-2017 | 08:02 AM
SB
The regulator should be after fuel rail...not right after pump.
You still have the VST module hooked up ? How about the mechanical pump?
Or are you confusing us by having a cool fuel system and this is a VST thread ?
Do you have photos or can draw a diagram exactly how you have it ?
SB is online now
Old 06-30-2017 | 08:59 AM
]Wow...I'm getting more confused... the vst is gone... mechanical pump is there... I was told from the shop that I needed a regulator after fuel pump before rail. Not trying to confuse anyone. I'm the one confused now...lol hope this drawing helps. Thanks for your help
Force265 is offline
Old 06-30-2017 | 09:06 AM
[img]webkit-fake-url://16b915eb-9747-428e-8686-e30148d7bb96/imagejpeg[/img]
Force265 is offline
