Wideband
Old 11-13-2016 | 03:01 PM
Default Wideband
I'm getting ready to get a wideband cause I don't feel certain that my carb set up is right using old school methods. I have the engine installed and I don't have a way to dyno it. Plus I have another carburetor so I want to set up both and see what I get. I have a Weber that came on the 350 Mag that I cannibalized for accessories and intake. I believe that is 600 cfm or maybe 625. I have rods, springs, and jets and I'm close on spark plug color. But I also have a Rochester in my basement that I was doing for a 79 350 Camaro...and the guy that owns it disappeared.
So since the Weber is just barely enough carb to spin 5200 according to some calculators I have seen, I think I'll run the Quadrajet for a try. I won't have to do a marine carb for the fuel telltale cause i am running an electric pump. Any worries with venting and etc?
The engine is a 9.8:1 forged piston 383 with Dart small runner iron heads and a roller valve train with a Comp Cams OE style CS 268XFI HR13 Cam
Valve Lift .570” I, 565” E. Duration at .050, 218 I, 224 E, 113 lsa, 109 icl. It has a nice quench height of .040".
It's very snappy, rips right up to wide open and then just stops accelerating. I think it's due to the small head ports. But maybe it's just as much as I'm going to get from a small block pushing a heavier-for-it's-length hull. I want to get what it can give so that's why I will put on the bigger carburetor.
I feel like I ought to go the last couple of tuning steps and get the AFR right.
Who has used the Innovate AFR kits? Are they good? Can I extend the wiring to my helm area for live use testing? I was thinking I would use one for setup and then remove it to my tool box so I don't have to think about powering the sensor heater and about wetting the sensor. I don't think that my cam is reverting anything, I have tall long risers that are dry way back. But no sense ruining stuff.
What other widebands are there for reasonable money. Any?
NHGuy is offline
Old 11-13-2016 | 08:35 PM
I am using, and have continuously used the Innovate MTX-L wide band for the last 6 years. Works great.
You would need to buy the extension kit to get the gauge to reach the helm/dash. That's what I did. The AFR gauge took the place of my fuel gauge.
I would run it full time because beyond the tuning and performance aspect it is also a tremendous troubleshooting tool to identify fuel or spark issues. I run a very similar motor with a bigger cam and have no reversion issues. I've got over 200 hours run time on the system. I feel naked without it.
Trash is offline
Old 11-13-2016 | 10:51 PM
What he said. ^^^
The wideband is very enlightening. You think that things are close but there's just no way to get spot on. I put a wideband on a tuned carb and picked up another 5mph with some jetting changes.
Baja Rooster is offline
Old 11-14-2016 | 06:50 AM
Love it guys! So since I have less cam I can probably expect to keep the sensor dry. I'm going to set it up permanently.
NHGuy is offline
Old 11-14-2016 | 10:37 AM
Just some more feedback regarding running and tuning. On the water running at cruise you will not be able to tell the difference performance-wise between 12.8 AFR and 13.2 other than the gauge saying so. So I don't sweat getting the AFR dialed in at say 12.8 rock solid from cold start to WOT.
In general I target the following ranges:
Cold start, no load, idle: 12.5 - 12.8
Warm idle, no load: 13.5- 14.2
Warm idle in gear: 13.5
Throttling up to get on plane (typically 17-30% TPS): 11.8-12.5
3000 rpm cruise 12.8-13.2
3000 to WOT 12.8 progressing to 12.2-12.5 at WOT
This has worked for my application and I am N/A. So take this merely as one data point.
If your AFR is grossly outside those ranges you will likely start to see performance issues. For instance if I richen the idle to 10.5 it sounds like a top fuel motor and the IAC goes bat **** trying to tame the idle. If I'm 14.7-15.2 at idle it gets very crisp but not very stable during shifts.
Also for reference my cam is a Crower hyd roller 221/230 @ .050", .525/.545 on a 1.5 rocker, 114 LSA on a 110 ICL in a 377" stroker (standard bore).
Trash is offline
