-   -   Nitrous on 454 mpi mag (https://www.offshoreonly.com/forums/do-yourself-boating-budget/343651-nitrous-454-mpi-mag.html)
SB 11-04-2017 05:06 PM
Originally Posted by Coolerman (Post 4591655)
Only hardcore racers use nitrous oxide systems!
With 40psi boost :)
getrdunn 11-04-2017 07:54 PM
Personally I think the hull would be the determining factor. 38 V bottom??? The problem I had was when I got caught for revenge day with empty tanks. Not cool..... plus a couple minutes wot isn't no where near enough especially when you keep pushing someone out further into rougher water.
phragle 11-04-2017 08:46 PM
If you want a drag boat, buy a drag boat.
if you want an offshore boat to go x mph at 5500 rpm, build it to do that. If you build it correctly to do that, it will. if you dont , it wont. If your using nos to make it do something its not built to do, eventually you end up with pieces instead of parts.
Nos has a place at the dragstrip or in little Jimmie's honda car with the coffee can full of bumble bees exhaust so he can make it from traffic light to traffic light in under 10 minutes,
sutphen 30 11-04-2017 09:33 PM
turbo,nitro motor is the only way to go.
getrdunn 11-05-2017 12:33 PM
Pieces are what I eventually ended up with. Had some unrecognizable parts during tear down. Mostly my own fault cause I was young and held the button to long. Even though I thought I had enough fuel to compensate it was obvious I didn't. A couple of spark plugs were burned right down to a few threads and piston came completely apart and transferred from side to side making a complete mess out things. That's when I met Valako and decided to make power other ways. Wish I still had the pics of that disaster but that was back in the 36 mm days.
Coolerman 11-05-2017 05:48 PM
"Nitrous does not blow up engines, people blow up engines!"
http://www.hotrod.com/articles/engin...-305-take-nos/
That being said, if you try to get by without setting the motor up right, or try pushing how much timing you can run or how far you can lean it out, nitrous will ruin parts very quickly......
Also, the only time you see nitrous explosions is generally when something in the valve train breaks.... And in drag racing, it is usually because people can't do a burnout and bang the motor off the rev limiter. Just watched a guy do the exact same thing the other weekend and the whole car almost went up in fire. The other cause of failure is a stuck solenoid from getting junk in the tanks and not being properly filtered.
sutphen 30 11-05-2017 08:49 PM
Engine Masters Ep. 13 Asks: How Much Nitrous Does it Take to Scatter a Stock Engine? - Hot Rod Network
https://www.youtube.com/watch?v=AScojLj139A
sometimes,,just some times the converter breaks and loads the motor down too much,you pop a headgasket and the explosion goes up the other cylinder and almost blows your scoop off,all at the 1000' mark.not that I know anything about that.:D
Skirby12 11-06-2017 04:09 PM
I agree. I don’t really see the benefit of nitrous in a boat. A car or truck that’s a different story
