Installing HP Transom Assemblies >
Old 03-01-2017 | 06:17 PM
If the cutouts are not already sealed, I would use penetrating epoxy on them. No need to glass.
Bob
Tidbart is offline
Old 03-01-2017 | 07:40 PM
On the fence on sealing up cutout and applying 4200 on transom assembly...will be tackling this project in a few weeks.
1MOSES1 is offline
Old 03-01-2017 | 10:04 PM
c_deezy's Avatar
Assuming you mean the foam gasket, as long as the transom is flat you shouldn't need any sealer. A little bellow adhesive in the corners between the gasket and transom assembly to help keep the gasket in place is all you need.
c_deezy is offline
Old 03-10-2017 | 06:07 AM
Originally Posted by AllDodge
Installed a new HP transom assembly dry, still dry
I agree, if your transom is flat you don't need any sealer. When I redid my transom I installed my new transom assemblies dry, still dry!!
TomR is offline
Old 03-10-2017 | 07:20 AM
Below the waterline, possibility of rotting the transom if it leaks, tough to see if it does, I'll put a thin layer of sealer on it vs worry about it or even think about it.
Unlimited jd is offline
Old 03-12-2017 | 11:50 AM
The sealant for me was added peace of mind. I know it isn't necessary and many don't use it. A little extra sealing can't hurt.
Crude Intentions is offline
Old 03-12-2017 | 12:20 PM
I'm removing one now that was installed dry, gasket shrank up and now it leaks BAD
Old 03-12-2017 | 12:25 PM
Guess there is a first time for everything but never heard of a gasket shrinking. Most time it starts to leak is when the transom gets soft.
AllDodge is offline
Old 03-12-2017 | 01:09 PM
Boat has 200 hours, been out of the water for 4 years. Transom is solid and flat
Old 03-13-2017 | 06:37 PM
Gaskets and any rubber material for that matter shrink, dry out, crack and eventually leak over time. What is everyone using 4200? Or something else? Thanks for the insight.
1MOSES1 is offline
