trim pump extension hoses
Old 03-01-2017 | 02:36 PM
Default trim pump extension hoses
I'm re rigging my bilge and need some longer hoses for my trim pump. Are there any extension kits out there that I can just add on? If not, what do I need to make some up??
Thanks in advance
Novaspd is offline
Old 03-01-2017 | 03:00 PM
Just measure and order. There are different lengths for the hoses coming off transom assembly and there extension hoses. I have hoses that go from my fwd bulkhead all the way to transom and tie into transom assembly hoses there
Crude Intentions is offline
Old 03-01-2017 | 03:33 PM
perfect, I'm going for a similar set up, the extensions your ordered. Are they a mercury part or aftermarket and who did you order from??
Novaspd is offline
Old 03-01-2017 | 03:52 PM
They came factory from fountain. I would just use google for trim pump lines. I tried to have one made locally and because it was 3/8 no one had the fitting in stainless.
Old 03-06-2017 | 09:07 AM
Doug russel Marine 32-89023a1
Knallan77 is offline
Old 03-06-2017 | 11:08 AM
vintage chromoly's Avatar
Go to your local hydraulic shop.
Measure what you want and your end configurations and have them made.
vintage chromoly is offline
Old 03-06-2017 | 11:25 AM
Mel Riggs. Riggs Marine will get any length you want
kvogt is offline
Old 03-10-2017 | 08:10 AM
Ayuh,... Trim lines are standard automotive brake line fittin' sizes,....
Dependin' on how creative ya wanta be, 'bout anything can be done with 'em,....
'course, they'd be hard lines, 'n not hoses,....
Most of the better Hyd. Shops can make up hoses any length ya want,...
Bondo is offline
Old 03-10-2017 | 08:43 AM
Moreland Hose, Oakdale, NY
631-563-7071
AZMIDLYF is offline
Old 03-12-2017 | 11:48 AM
One of the issues I had with local hydraulic shops was the fittings are stainless. 3/8 I think. None of them carried them in stainless. Fwiw make sure you keep the stainless ends.
