stinger mounted brackets
Old 03-21-2017 | 03:53 PM
Default stinger mounted brackets
I am planning on using some aluminum angle to mount my oil cooler close to the engine on the stringer. This will not have to support a lot of weight and will have 4 brackets, so would you suggest just screwing it to the stringer or using a through bolt? Also do you use something to seal the exposed wood after it has been drilled?
thanks
Tahoe540 is offline
Old 03-21-2017 | 05:04 PM
vintage chromoly's Avatar
Through bolt.
Sealed mine up with 4200
vintage chromoly is offline
Old 03-21-2017 | 05:08 PM
I just did exactly what you're talking about.
I used 6061 angle and through bolted with a stringer washer on the opposite end. I actually painted inside the drilled holes with a hobby brush and then sealed all the holes with the 3m 4200.
I had all my aluminum brackets annodized so they wouldn't corrode and they look nice too.
Old 03-21-2017 | 05:13 PM
Wow that looks so nice vintage chromoly. Thanks for the info guys, will get the holes drilled and sealed.
Tahoe540 is offline
Old 03-22-2017 | 01:06 AM
Black zip ties would look better
Griff is offline
Old 03-22-2017 | 05:04 AM
Good eye Griff.
Rest assured, those are cheap ties and only for mock up.
The permanent Ty raps have the metal tangs in them and are black.
