what wrong with my 383 stroker ?or i am over prop
I need more than that. EXACTLY which hull/manufacturer. What out drive (Bravo 1, Alpha, other?).
What GPS speed are you getting and at what rpm? Data points at 3000/3500/4000 etc will help with suggestions.
Is the drive trim working properly?
What is the weight of the boat (fuel, passengers, hull etc)?
Why is it like pulling teeth to get boat info ? We are trying to help but you are making it painful to those trying to help.
sorry for my English language . i truly ask for help ,but my English not enough to make your understand me here.i will try to up load video about my boat ,i do not lie with people here,and new with my first boat .
I have a bigger heavier boat with a deeper v... Should be about the same hp (310) though I probably have more torque. Regardless I see 60 at 4600 rpm.
Either your speedo is wrong
Your prop is slipping excessively
You have the bow buried
Or your numbers are off
That rpm x that ratio x the prop pitch = mph. Some factor in the equation is off.
