Bravo 1 gear set failure. Lower Unit check >
Old 08-06-2017 | 10:06 PM
Default Bravo 1 gear set failure. Lower Unit check
Had a few teeth break on the forward hear set . I noticed it making a small knocking sound about 5 miles from the dock . I got the the top case apart .
What will I need to check for on the lower unit
Yes there was some metal on the lower plug magnet
Plus Man is offline
Old 08-07-2017 | 12:45 PM
all going to have to come apart at this point
ezstriper is offline
Old 08-07-2017 | 06:07 PM
Lower needs to be taken apart cleaned and checked or you'll be sorry
Clustergear is offline
Old 08-08-2017 | 06:50 AM
will pull it apart
THX
Plus Man is offline
Old 08-09-2017 | 06:58 AM
After you clean lower out. If when setting rolling torque on pinion and overall preload on prop shaft. You feel rough spots, needle on torque wrench starts jumping around metal filings have imbedded into bearing rollers.
