-   -   Best way to do a water pressure relief valve (https://www.offshoreonly.com/forums/do-yourself-boating-budget/353184-best-way-do-water-pressure-relief-valve.html)
farmo83 04-04-2018 02:00 PM
I have a standard Bravo 1 that I'm swapping the lower for a lower water pick up shorty. I've read it's wise to put a water pressure relief valve on your setup. Is the mercruiser kit the best option ?
Genuine Mercury & Mercruiser parts. 863208A3 VALVE KIT-RELIEF Genuine OEM Mercury Marine-Mercruiser part
I know CP has other relief valves but I think the standard water lines are bigger then 3/4
Water Pressure Relief Valve 3/4" NPT - CP Performance
If there is some other aftermarket way to do this I'm all ears.
thirdchildhood 04-04-2018 04:58 PM
Imco shorty? Not only is the water pressure sky high but every one I've seen had cavitation burn aft of the inlet. I installed a relief valve but ended up having the lower welded up and reconfiguring the inlet. It took some experimentation but I got my pressure where I like it and I took off the relief valve. This is with a closed cooling system which can handle more pressure.
https://cimg5.ibsrv.net/gimg/www.off...a607aab08c.png
Griff 04-04-2018 08:47 PM
Use one of these in the main water inlet hose https://teaguecustommarine.com/em001...elief-tee.html
CP has one listed for 1/2 NPT but not for the 3/4 NPT 1-1/4" Pressure Relief Valve Fitting For Inline Use, 1/2" NPT - CP Performance
Revd Up 04-04-2018 11:15 PM
First I would install a water pressure gauge . Then most likey you will need to install a water pressure relief valve to relieve the pressure .
Brembofreak 04-05-2018 01:40 AM
How much waterpressure (on smartcraft)is ok on an 600SCi and is it ok to make 1/2 or 3/4 valve in the seastrainer??
I try to run Standart XR lower with dualwaterpickup with my new engine! i get to much pressure there???
Michael
farmo83 04-05-2018 09:11 AM
It's a sportsmaster, I thought pretty much any boat with low water pick up needed one
Revelocity 04-05-2018 10:20 AM
I used the CP Performance relief valve and it managed my water pressure nicely in fresh water. My oil cooler had an available 3/4" water FPT to install the valve.
