New heads install
Old 06-10-2018 | 08:25 PM
Default New heads install
so i need to install new heads on my motor. my question is should i install new push rods and rockers or is it ok to reuse the ones from the old heads?
my motor is 2011 crusader sd power pack mpi 350ci 330hp 294hrs
inlinepwr is offline
Old 06-10-2018 | 09:49 PM
Its fine to reuse, but best if you keep the same pushrods with the same rockers. Just inspect each one carefully.
Griff is offline
Old 06-10-2018 | 10:32 PM
Rookie's Avatar
It's ok to reuse if they are the same head and have not been cut. Aftermarket heads or other model # you'll have to measure and replace if necessary.
Rookie is offline
Old 06-24-2018 | 09:24 PM
lube them up and install them,you will be fine.
mike tkach is offline
Old 07-07-2018 | 06:16 PM
Check geometry if you deck the heads or block. Also check geometry if you change to a different head, rocker, head gasket or valve stem length. Sometimes you need a different pushrod length. It's good practice and you won't have that issue to worry about.
Most don't need a change, but if you miss something it can get ugly.
NHGuy is offline
