Oil or Gas in cooling system >
Old 07-20-2018 | 11:41 AM
Default Oil or Gas in cooling system
I have pro-charged 502 Rage. Set it up 8 years ago with AZ speed & marine. Has been totally reliable and bulletproof. Maybe 450 hours.
I noticed a petroleum sheen on shutdown as raw water cooling drains from intercooler dump (raw water draining down from block through intercooler and out). I'm not sure if its oil or gas. What is most likely source? No water observed in oil (milkshake). Blown head gasket? Failed oil cooler or cool fuel? Where to start? Seems to be running fine.
Thank you all in advance for any suggestions.
collin is offline
Old 07-20-2018 | 12:20 PM
I’d give Arizona a call but other than that just start pressure checking the easiest items first. My first guess would be the oil cooler.
Baja Rooster is offline
Old 07-20-2018 | 05:00 PM
Pressure gauge from welding supply. Tire fitting from parts store. Hose and tees from lowes. Quicky pressure tester.
dereknkathy is offline
Old 07-20-2018 | 05:08 PM
Agree pressure test, and would think the oil cooler
AllDodge is offline
Old 07-21-2018 | 11:44 AM
A trip to the hardware store to buy a 3’section of appropriately sized hose and 2 barbed couplings to bypass the oil cooler solved my sheen investigation. After installing the bypass contraption the water was free of sheen.
Fischan is offline
Old 07-22-2018 | 06:51 PM
Thank you all. Cracked oil cooler. Now solved!
collin is offline
