Camshaft Questions
Old 06-13-2019 | 06:19 PM
Originally Posted by Bang Bang
Is the comp cam really identical to the crane? I was looking for lifters for the crane and came out at $880, for the crane it's only anywhere in the $200s
I don't really know which i should choose.
No the comp cam is identical but it is so close it would be hard to see any performance differences between the two. Both great marine engine cams
Camalot is offline
Old 06-13-2019 | 11:13 PM
Originally Posted by Griff
Crane 741 cam and Isky 9005 valve springs
winner winner chicken dinner.
mike tkach is offline
Old 06-14-2019 | 12:53 AM
I think comps are cast cores?
hogie roll is offline
Old 06-14-2019 | 09:48 AM
Hardened steel billet with a cast distributor gear pressed on.
Baja Rooster is offline
Old 06-14-2019 | 09:59 AM
good point talking about cast cores.i would never use a hyd roller cam made from a cast core,espically in a marine application.
Old 06-14-2019 | 02:46 PM
i think i take the comp cam combo and safe $650
i can put this in a better intake, makes more sence.
Bang Bang is offline
Old 06-14-2019 | 02:51 PM
SB
Are you looking at kits where the Comp Cams uses factory style dogbone lifters and the crane uses retrofit link style ?
SB is offline
Old 06-14-2019 | 02:55 PM
Yes.... comp cam refers his dog bone lifter for $218.
crane refers lifters for $880. they might be better, but do i really need them? Is there an improvement over the comp cam set???
Old 06-16-2019 | 11:50 AM
how much lift can you put in motor??
i have isky cam 710 lift,,red ball series lifters (no needle bearings, was told the best market)about 1000$$for lifters
personally,, i would not want to pull a motor to change a cam. (unless its easy job..hahaha)
just had to pull my motors again to address and change water pump set up. dont ever want to pull motors again....!!!!!
flashgordon is offline
Old 06-16-2019 | 01:14 PM
.710 is a lot lift....
i gave johnson lifters an email to get the right part number for my project, but did not get any response.
Lifters seems to be a neverending story in my build.
Perhaps i should take the comp cam set to come to an end.
