Combustion chamber clean up >
Old 09-30-2018 | 05:19 PM
Default Combustion chamber clean up
i recently purchased some EQ heads and the combustion chambers are little rough.
what is the best tool / process to clean them up with out effecting them
thanks in advance
Bajaorlando is offline
Old 10-01-2018 | 04:27 PM
Many ways however if your just wanting to polish up to help eliminate carbon build up.
getrdunn is offline
Old 10-01-2018 | 04:33 PM
What John said. ^^^
i cleaned up my Edelbrock heads and added about 10cc so go gingerly, but I believe the EQ heads are better to start with.
Baja Rooster is offline
Old 10-01-2018 | 04:37 PM
Won't need low grit as shown in first pic. Just an example and handy for stripping gaskets etc. I use the DocaDisc all the time on a number of projects. Pic 3. Very handy. You can end up with practically a mirror finish if you wanna spend a little time. No hp gains however I understand what your up to.
getrdunn is offline
Old 10-01-2018 | 05:32 PM
Thanks guys
thats what I was thinking
I just do not want a problem with detonation
Old 10-01-2018 | 10:01 PM
Don't forget matching the runners to the gaskets
f_inscreenname is offline
Old 10-02-2018 | 11:13 AM
Spray some water in the intake (while hot and running) give em a nice steam clean.
ICDEDPPL is offline
Old 10-02-2018 | 11:56 AM
The heads are new and not on the engine, but i guess you were joking
Old 10-02-2018 | 02:20 PM
SB
He didn't read the thread correctly. It seems he thought your comb chambers had a lot of carbon and schit that needing cleaning off.
SB is offline
Old 10-02-2018 | 02:36 PM
Originally Posted by Bajaorlando
Thanks guys
That's pretty much the reason I went after my chambers, and I just enjoy putting nice pieces together. But with that said, I've never heard of anyone solving detonation issues with chamber polishing. It seems to be a pretty nil issue in the big scheme of things.
