Converting from cable steer to hydraulic steering. >
Old 03-28-2019 | 02:26 PM
I did the Mayfair complete helm to wing plate from CP for like $3500. No special tools and it bleeds itself. Gravy job even for a rookie. You will need a bench vise for hose end assembly
ph1971 is offline
Old 03-28-2019 | 11:18 PM
Originally Posted by zz28zz
I did this 3 years ago. It's a big job and requires lots of planning, measurements and some precise drilling.
If your planning on used equip, it's best to find a setup being removed from a boat that's similar. That way you get everything.
Missing hardware can add up quick. I was missing a special stud needed to attach the bracket to the drive. Had to have a machine shop make a replacement.$$$
How much time and cost was the project?
drumerjb is offline
Old 03-29-2019 | 01:42 AM
It was done in the off-season so I wasn't in any hurry. Took abt a month altogether. I made glass liners for the thru-hull bolts and hyd fittings and I gave it a week for the epoxy to dry. Machine shop guy did the work on the side, so another week there. Spent the most amount of time researching, planning, and measuring. Paid $1700 for everything except that one special stud ($80). Bought a drill press (I wanted anyway) to fabricate drill guides ($400), A set of brad point drill bits (~$40) Couple tubes of epoxy ($30) Almost forgot, a Craftsman low-profile type rolling stool just to be comfy down at that level for long periods ($30). Call it $1850 not counting the drill press or stool.
zz28zz is offline
Old 03-29-2019 | 08:07 AM
How how many hours total do you think you have into it 50 60 70 hours?
drumerjb is offline
Old 03-29-2019 | 08:13 AM
TomZ's Avatar
My installation wasn’t as elaborate at the transom, but I know I spent a few days making the helm mounting plate for my Formula’s dash. It was also a major pain getting the old cable system and its hydraulics out. UPS also lost my Latham drive brackets (that amazingly were sent back to Latham because their address was stamped on the brackets!).
I probably had 30 hours in the whole thing. It would have been longer had I needed to make the lines. I got the entire used system from a similar sized boat; everything fit perfectly.
TomZ is offline
Old 03-29-2019 | 08:28 AM
Nice, I'm considering upgrading my 28ss to hydraulic steering eventually. I was figuring about 40 hours to do it so. I wasn't really that far off. At any rate it is one of those big projects. Thanks for the info.
drumerjb is offline
Old 03-29-2019 | 04:46 PM
40 hours sounds abt right. Try and find some quality pics of your setup online. That helps a lot. Probably the 2 most important things: Make sure the hyd cyl/s bottom out before the drive/s hit the hard stop and located the transom plate/s on the same plane as where the drive/s pivot up/dn.
zz28zz is offline
Old 03-29-2019 | 05:47 PM
Yes measure 10 *, mock it up again to verify, measure again before drilling and mounting cylinders and fittings. I hear you, you only get one chance doing it or you're doing fiberglass repair.
drumerjb is offline
