BBC chamber volume sizes
Old 11-27-2018 | 10:24 PM
phughes69's Avatar
Default BBC chamber volume sizes
What is the chamber volume size on the late 70's 330 BBC heads?
phughes69 is offline
Old 11-28-2018 | 11:01 AM
118cc for the peanut port heads. Take the head number and do a google search for sure.
f_inscreenname is offline
Old 12-05-2018 | 07:37 PM
119 on the 049's. That's the non peanut port. Std oval port then.
getrdunn is offline
Old 12-14-2018 | 08:58 AM
most heads after 72 are 119. at least RATED 119. get a Walmart 4 buck flavor shooter in the cooking section. 30cc syringe. accurate enough. piece of plexi about 6 inches square. drill a hole about 3/8ths on one side. grease plexi and stick it to the head. start shooting water in to the hole. with valves and spark plug, obviously. 25cc at a time. now you know the chamber volume. the heads from an 02 461 hp 502 are 113.5cc. they look just like the 119 cc peanut head chambers I have.
dereknkathy is offline
Old 12-14-2018 | 09:23 AM
is that 461 hp 502 a gm crate engine?
mike tkach is offline
Old 12-16-2018 | 04:26 PM
Yes. Bought it with cracked block. Got frozen.
Old 12-17-2018 | 02:40 PM
my 781s both measured at 118 for what its worth
beaver 3 is offline
Old 01-05-2019 | 07:59 PM
Most likely 118 as others have said
offroadr is offline
