how to determine if motor is worth supercharging >
Old 03-01-2019 | 08:37 AM
Default how to determine if motor is worth supercharging
is there a good way to determine if motor is worth supercharging 454 carb motor
thanks in advance
cig20 is offline
Old 03-01-2019 | 10:34 AM
Little more info on the engine. If you wanna make power without a hassle no reason not to. If it's time for a rebuild nows the time to decide so you don't do what I did changing directions mid stream.
getrdunn is offline
Old 03-01-2019 | 02:44 PM
Which 454 carb motor???
phragle is offline
Old 03-01-2019 | 07:05 PM
I would also rephrase the thinking to is the boat worth supercharging? You’ll most likely have to reinvent the fuel system, oil system, coupler, outdrive, etc.
Baja Rooster is offline
Old 03-01-2019 | 08:45 PM
22 donzi trs drive top half of motor done 25 hrs ago
cig20 is offline
Old 03-01-2019 | 08:55 PM
What size blower you looking at and also what's current compression? You have the merctrans or bw c72? An inner cooled 177 you'd probably be fine if that's what your thinking.
getrdunn is offline
Old 03-01-2019 | 09:04 PM
was think a procharger m1 intercooled
cig20 is offline
Old 03-01-2019 | 09:46 PM
1. What 454 ?? the 330 or the mag?
2. a 22 Donzi?? unless you have a blower laying around.... about 525 na hp and a bravo with a decent x dimension will get you moving pretty good.
phragle is offline
Old 03-02-2019 | 09:06 AM
motor is 1979 original to boat has approx. 350 hrs before top half redo
22 classic
cig20 is offline
Old 03-02-2019 | 09:12 AM
F-2 Speedy's Avatar
Don't take a chance on blowing up the original engine, I would start fresh and build a 454 mag or 502 gen 6 both should have forged internals and wont break the bank .....jmo, their only original once.
F-2 Speedy is offline
