Help! unable to maintain power >
Old 03-06-2019 | 02:06 PM
Originally Posted by drpete3
Well I have a new cap. But is there something under the rotor I should look at?
look for excessive corrosion.....
phragle is offline
Old 03-06-2019 | 02:34 PM
I didn't mean to be sarcastic at all but yes as others chimed in MSD distributors among others have a tendency to corrode if not maintained properly. Been many threads on the subject over the years with a crc coating of some sort to help preserve the life of them. MT posted different times the exact name of spray used. Just look under rotor and I'd be shocked if after 7 years you don't quickly identify what we're saying. Good time of year to refresh/replace some components to avoid down time during the short season we have up here.
getrdunn is offline
Old 03-06-2019 | 02:37 PM
Aluminum or cast iron heads? Be careful removing spark plugs....
getrdunn is offline
Old 03-06-2019 | 02:46 PM
Aluminum heads. And Im not changing my plugs till I have to. I dont think I can without taking off the headers and Im not doing that. I mean I looked under the rotor when it was off and the springs looked rusty but IDK.
drpete3 is offline
Old 03-06-2019 | 02:49 PM
it Did not look like this.
drpete3 is offline
Old 03-06-2019 | 02:52 PM
Yup. Don't feel bad it's normal after a season or two.
getrdunn is offline
Old 03-07-2019 | 07:10 AM
I dont get this statement. If your having a problem and your plugs and cap were all 7 to 8 years old why wouldn't you do a complete tune up to both engines. Plugs, wires, cap, rotor, and all fuel filters/ separators. It's a good bit of simple work but it solves alot of little issues on old worn out parts. I only have to maintain one engine in my boat but if it needs maintenance I do it not just half of it at a time. IMO I would start with a full maintenance tune up and this way both engines have full tubes up at the same time intervals. Good luck I hope you get it sorted out.
DBleil89 is offline
Old 03-07-2019 | 09:46 AM
TomZ's Avatar
Plugs, cap and rotor, wires on BOTH engines. 7-8 years is too long. I check plugs at the beginning of the season, and replace every other.
As others have said, look at fuel delivery on the secondary side. It might be a good idea to pull the carb apart to give the metering blocks a good cleaning. Make sure all of your grounds are good too.
TomZ is offline
Old 03-07-2019 | 01:18 PM
I misread or didn't see the writing on post 25. Glad it wasn't yours drpete3. lol... Just a suggestion though regarding your spark plugs over and above your existing problem I would strongly suggest to change plugs and reinstall with copper anti seize. At the very least make an attempt to remove a few that are easily accessible just to make sure they'll back out ok. I've seen it go both ways in much shorter period of time. Had one come out of a friends vehicle right with the threads from the aluminum head. If run into difficulties best to work both ways left and right until out while using some penetrating spray.
getrdunn is offline
Old 03-17-2019 | 11:17 AM
i agree with others on here,,,,sounds like fuel issue........
i had a similiar issue on my 34 sea ray..boat would run fine 3000 rpm, then the port motor would start losting power
if i gave it more throttle it would stall out...but would idle forever
i think there was issue with tank...garbage...old...etc...
sway carbs coils new fuel pump,,new fuel line..
never figure it out .
sold boat......
flashgordon is offline
