-   -   Exhaust Manifold Mounting (https://www.offshoreonly.com/forums/do-yourself-boating-budget/359879-exhaust-manifold-mounting.html)
LTZCrew 04-01-2019 11:49 AM
I did do a search and could not find anything - maybe i didn't look hard enough.
i have a 575sci with AFR heads and found the stock bolts are a bit of a PIA to use. i know on cars with heavier manifolds(trubos and stuff) builder likes t o use studs to help with sealing and the weight.
has any one used studs on marine manifolds - cmi style headers?
was thinking it would make installing them easier and help with gasket sealing
Help a noob out?
Crude Intentions 04-01-2019 11:56 AM
In a single don’t think it would be an issues. Studs aren’t used in a twin as you’d never get the manifolds off between engines. There may be other reasons also
Griff 04-02-2019 01:28 AM
All the info you need here https://www.offshoreonly.com/forums/...t-525efis.html
LTZCrew 04-02-2019 09:03 AM
Originally Posted by Griff (Post 4679958)
thank you!
NHGuy 04-03-2019 03:41 AM
To avoid the pain in arse of holding the manifolds in place while starting the bolts do this.
Get 2 longer bolts and grind off their heads to make mounting guides.
Slide on the gasket, then manifold. Once the manifolds are lined up put in 2 real bolts, remove the headless bolts, and install the remaining real ones.
flashgordon 04-03-2019 06:32 AM
i think it was mentioned already, but i use studs on just the end holes on each head.
the header gaskets are designed that way also
its enough to get headers on and started.
i have stelling headers, they are pretty heavy.
good luck ...
gw
