Fuel Line Tank Return from Regulator >
Old 05-19-2019 | 04:08 PM
I was told at the Holley EFI class that I also need a dip tube to reach below the surface of the gasoline to prevent aeration if returning straight to the tank.
wasn`t a problem with carbs but that's 7psi vs. 43. so...
ICDEDPPL is offline
Old 05-22-2019 | 11:56 AM
I ended up running two -6 returns to a single -10 and placing it part way up the tank away from the pickups.
I can't see any way to run it back to the Hardin filter heads without causing heated fuel or some weird fuel pressure issues especially with the amount of fuel the A1000 will move.
Speaking of FP, what should I start out with pressure wise at idle? I am running a regulator that is 1 to 1 boost reference. I believe the factory is 43-45 psi for MEFI 3?
justinp20012500 is offline
Old 05-22-2019 | 12:31 PM
Originally Posted by Team Archer
WE run back to the filler hose with a sleeve so that we don't aerate the tank. WE just run 1 larger line from the engine room and tie the 2 returns together. Regards Dan
Ive done it this way on multiple projects and never had an issue.
SS496 is offline
Old 05-22-2019 | 05:11 PM
Good to know, I'll try it out one day as the regulators are mounted to the filter heads.
