D.U.I. distributor wiring Alpha One >
Old 06-15-2019 | 10:40 PM
Default D.U.I. distributor wiring Alpha One
What is the correct way to connect the Alpha One shift interrupter leads with a DUI non-efi distributor? Going from T-Bolt IV harness to D.U.I.
94sylvan is offline
Old 06-16-2019 | 12:42 AM
The alpha shift interrupter grounds out for a momentary stall to get in and out of gear.
Crude Intentions is offline
Old 06-16-2019 | 06:15 PM
SB
Pretty sure attach it to the tach wire for these DUI app's.
SB is offline
Old 06-18-2019 | 09:57 AM
I attached my to the tach wire.
Tahoe540 is offline
Old 06-18-2019 | 11:11 AM
Thank you, yes that is what I did and works good.
94sylvan is offline
Old 04-09-2024 | 10:32 PM
Default Wiring
Hi everyone Roy here. Say I also installed the d.u.i. and just want to varify is that the green and white wire from my interrupter switch that goes to the tach .... right ?
Cruiserman is offline
Old 04-10-2024 | 11:36 PM
I can’t speak to the alpha setup, but wiring the DUI directly to the battery and using the stock ignition wire to trigger the relay made a huge difference in performance on my setup. Anything less than a 12g to the DUI is inadequate.
Baja Rooster is offline
Old 04-11-2024 | 03:51 AM
SB
Yes.The green/white is switched ground.
The other is always ground.
See this:
SB is offline
