Bilge Flooded - 10qts of water in oil pan >
Old 06-24-2019, 03:41 PM
k5 are you a marine mechanic ?
nope. Just an idiot with more money than brains... why else would I have a boat?
In all honestly, I'm very much a DIY'er, but pulling the motor out might be outside my wheelhouse.
k5grady is offline
Old 06-24-2019, 03:42 PM
The recommendations have been straight up..... do your due diligence in the drain/refill - run and repeat until the oil is 100% clear and then consider a shortened oil/filter interval once you are back on the water.
Seems crazy that people would avoid a bullet with a full tear down and then worry about the cost of another oil/filter change.
speicher lane is offline
Originally Posted by BBYSTWY
I have done the above mentioned method several times on boats that have completely sunk and never had an issue...I would also pull the plugs and roll the motor over without plugs in it just to verify there's no water on top of the pistons...I know its a scary thing to have water in the motor but as long as you didn't run it with the water in the oil you should be fine...usually takes 3-4 oil changes to get all the water out from my experience but that was on motors that were completely under water
Like they said above as long as you watch the oil pressure gauge and get it up to temp it will burn all the water out...don't be alarmed if you see extra condensation and a lot of steam on the first fire...it happens lol
Good info!
k5grady is offline
Old 06-24-2019, 03:46 PM
F-2 Speedy's Avatar
Received 3,051 Likes on 1,357 Posts
just asking, if you were you could pull the distributor prim it with a drill without starting it, then reassemble, your getting solid answers to get it back in the water, good luck
Edit: where are you located, someone on here my be close to you for help
F-2 Speedy is offline
Old 06-24-2019, 06:40 PM
I agree with pulling the plugs and roll the motor over without plugs in it just to verify there's no water on top of the pistons.You can turn it over with the starter without the plugs several times to get oil circulating. Less pressure
on the motor.Then pet the plugs in and run it for several minutes,then bring it to operation temp
Donzi Z22 is offline
Old 06-24-2019, 10:48 PM
I would pull the spark plugs,, remove the distributor and install a tool to Pre-Oil the engine ,, before starting it.
253 is offline
Old 06-25-2019, 12:28 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Do not use synthetic oil for your flushing. Just buy something cheap as mentioned, normal dino oil.
Just a few tablespoons of water mixed with synthetic oil, and it look like the whole thing is full of water.
Sydwayz is offline
Old 06-25-2019, 12:55 AM
I'd pre-oil it before rotating crank at all. There may be water trapped in the oil passages. If so, you want to flush it out (by pre-oiling). Need to get oil on those bearing surfaces ASAP. The sooner you get it running and up to temp the better.
zz28zz is offline
Old 06-27-2019, 07:56 AM
Talking
BBYSTWY ,,,pulling plugs and spinning motor is the best direction for first thing to do!!!!!
then change oil and filter several times,,,,always running temp up.
flashgordon is offline
