upgrading throttle/shift controls?
look here: https://www.mercruiserparts.com/bam/...32079/8457/285
its a breakdown of the mercruiser zero effort controls...basicly same as the gaffrig/livorsi stuff
the connectors im talking about are part #40
they thread onto the ends of the cables and then attach to the shift/throttle levers
-Wally
-Wally
awesome. thanks for the help so far. i just bought a shifter assembly off ebay so once it gets here i'll determine what else i will need. im hoping my cables will be ok with the new shifter. is there a way i can wire up the trim switches so that both drives go up and down with one switch? thanks for all the info so far! i was about to bail on this idea lol.
yes you can....matter of fact i just found an old gaffrig trim switch that mounts on the throttle stick the other day in the garage.....it involves wiring in some diodes to keep from back feeding the other system but yes it can be done
-Wally
-Wally
no, wiring up the switch to the tabs is easy if you have basic electrical skills....its just a simple momentary on/off/on switch with 3 wires.....one wire will have 12V+ and the other two wires each get split into two braches to each tab up/down wires...you just need to install 4 diodes to keep the power from back feeding the other tabs when you are using the standard dash switches so the other tab doesn't operate at the same time when doing so...
-Wally
-Wally
Hi there. I know it's an old thread, but does anyone know if I leave the shift assist spring thing in place when installing livorsi or gaffrig controls? ( I'm replacing the stock mercruiser 3300 assembly (twin handles) to a livorsi 4 handle controller.
It seems like the shift assist wants to force the shifter into neutral. THanks
i know this is an old post
but my 261 has Morse plson
plain alum big item on side of binnacle
throttles have holes for trim switch..but be dammed i cant find one
gaffrig has several that look like direct bolt ins with trim switchs
in fact if order them i will post up the part numbers
i have to go get a few pics for them to verfiy fit etc
gaff
gaff
Those never came with built in trim switches on the controls
You may able to make these work Throttles Archives - Livorsi Marine, Inc.
