Engine cooling - Std Bravo lower unit pickup vs transom mount water pickup >
Old 07-23-2019 | 12:20 PM
1 MAIDEN AMERICA's Avatar
160* sounds fine to me
1 MAIDEN AMERICA is offline
Old 07-23-2019 | 12:58 PM
Originally Posted by flashgordon
wow ,,this is all new to me
i have transom water pickup
goes to strainer , then oil coolers, then pump to motor.
i have never noticed any issues, but my boat is not a 100 mph boat...
should i be considering adding a relief valve?????????
Do you have a water pressure gauge?
payuppsucker is offline
Old 07-23-2019 | 01:01 PM
It keeps going... I haven't pushed it any farther to see when/if it'll stop
89Force235 is offline
Old 07-23-2019 | 01:05 PM
Originally Posted by payuppsucker
I've never converted from a drive source to a transom style pickup but most of my boats have had transom pickups. If you go with a transom mounted pickup you will need to add a pressure relief valve between the pick up and the pump to bleed off some of the water when running at speed.
Hardin also makes an adjustable pickup.
I read some place that the relief is not necessary as long as you've dialed in the pickup with a gauge and you're not flying the boat out of the water. The author noted the spikes in pressure are from re-entry.
Four what its worth my boat doesn't fly but does run about 75mph on the top end.
Old 07-23-2019 | 01:17 PM
no i dont have water pressure gauge,,,,
my boat is NOW closed coolant system..
dont know if that makes any difference...
but just posting that..
motors use to run 140-160 no thermostats
flashgordon is offline
Old 07-24-2019 | 07:31 AM
You should be good to go without the regulator.
Old 07-24-2019 | 08:01 AM
I converted my boat over to transom adjustable pick ups and love them , The only problem I encountered was breaking the welds off the pick ups so I welded the pick ups after I checked the pressure and then they were good. Then when I added two stage sea water pumps and intercoolers I did not have enough pressure at speed so I fish mouthed the bottom of the boat right in front of the pick ups and I have 15-17lbs of pressure at a little over 100mph engines run nice and cool.
green lightning is offline
Old 07-24-2019 | 01:08 PM
Running only 28* of timing will create more heat as well.
Griff is offline
Old 07-24-2019 | 03:22 PM
Thank you for the post! Why did you add the two stage pumps? Not enough volume to cool the boat?
Old 07-24-2019 | 03:23 PM
thanks for info ''payupsucker............""
