Gimbal bearing
Old 07-22-2019 | 08:54 PM
Default Gimbal bearing
Smoked an older coupler yesterday running cruising speed. My engine was previously out of alignment pretty bad. Replaced the coupler today and was worried about the gimbal bearing. I ordered a new bearing and waiting on it. The old bearing seems fine and articulated well with realigning the engine tonight. It is smooth and turns just fine, the bearing seems to move better now that it did with my first realignment. I was wondering if a gimbal bearing could have too much movement or too easy of movement for alignment?
captbones is offline
Old 07-23-2019 | 03:40 PM
If the swivel movement is free and easy, that’s not normal as far as I know. The rotation should be nice and smooth but changing the bearing angle should require inserting the alignment tool and bumping the other end of it deliberately. Good luck and don’t use a cheap replacement.
ph1971 is offline
