-   -   Leaking trim pump motor (https://www.offshoreonly.com/forums/do-yourself-boating-budget/362207-leaking-trim-pump-motor.html)
flashgordon 08-03-2019 06:43 AM
i have discovered that my port trim pump has a slight leak.
it does not look like lines, the bottom of the fluid reservoir is wet.
after looking at photos, looks like there is a screw in center of reservoir? j1171 pump trs drive
maybe this is leaking??
will address this today.....any ideas??
thanks............
SUPERSTITIOUS 08-03-2019 02:09 PM
Leaking out of the vented Cap ossibly?
flashgordon 08-03-2019 05:11 PM
well , its a cracked fluid reservoir ....
i read or saw , it stated online somewhere that the tanks can crack.
https://cimg1.ibsrv.net/gimg/www.off...a0cb925e8e.jpg
https://cimg9.ibsrv.net/gimg/www.off...cc0e4e31bf.jpg
new one 33 bucks............................................. .
Craney 08-03-2019 05:17 PM
Don’t you wish all problems could be fixed that easy.
compedgemarine 08-03-2019 05:57 PM
pretty common. I have replaced a dozen or so of them. they split out at the bottom screw lots of times or get old and warp so they dont keep pressure on the seals.
