454 rear main leak
Old 08-07-2019 | 09:25 AM
There are 3 oil passages with pipe plugs around the rear cam journal area and also one in the rear of the block below the distributor, something to check.
rspillman88 is offline
Old 08-07-2019 | 12:19 PM
Originally Posted by rspillman88
Its definitely dripping off the oil pan right at the rear main
its amazing how a tiny stream of oil can go unnoticed and makes its way all the way to the pan and drip, especially when it is hot. i saw similar drips a few months back and was convinced it was rear main seal, but it was valve covers.
I would definitely reseal (or tighten the bolts) on the valve covers and clean it all really well before any more major surgery.
sailtexas186548 is offline
Old 08-07-2019 | 12:52 PM
okay so I looked really well behind the valve covers and they are clean down to the block. The whole top half back of the motor is clean and dry not even so much as dust on it
Old 08-07-2019 | 04:08 PM
Might be the oilpan gasket in the corners where the cap meets the block. That spot is a typical suspect if the ultra grey gob wasn’t big enough. Or like I eluded to in the previous post, Felpro’s fancy reinforced one piece gasket turned into a crumbled mess in no more than 15 hours recently. I have used this gasket before with no problems so I have to guess that it was a composition problem in the rubber. Don’t know what gasket is in your application. Unfortunately the only cure is pulling the pan off.
ph1971 is offline
Old 08-07-2019 | 08:16 PM
That's the spot I'm thinking as well. Oh well I dont have time to mess with it so into the shop it goes
Old 08-08-2019 | 10:21 AM
The brass fitting that screws into the oil pan drain hole is tight and has a sealing washer on it right?
oconnor marine is offline
