Quickfuel (like Holley) power valve >
Old 08-31-2019 | 04:22 PM
Originally Posted by sutphen 30
all this talk about jetting and fuel leakage.
I'll just push a few keys on a keyboard and dial my fuel in,,fuel injection baby,all the way.
Probably where im going this winter on the car. Esp since im gonna need a controller for the 4L80E im installing, since holleys ecu can do that, why not go full efi
MILD THUNDER is offline
Old 08-31-2019 | 10:34 PM
Rookie's Avatar
I just started my EFI journey. I installed 1 EFI intake the other week. I Have the fuel rail and injectors installed and a carb on top. LOL
Need to add all of my sensors, wire harness routing and where I want to mount my ECU's. Also want to boat at the same time.
Rookie is offline
Old 10-01-2019 | 08:42 AM
Had enough of that edelbrock pile of junk. Picked up one of those "brawler" series carbs. 850cfm double pumper. Really nice carb for the money. Billet metering blocks and baseplate, screw in bleeds, and so on. Was only $436 bucks new from summit.
Car runs MUCH stronger. No more hesitations, bogs, or any of that. Throttle tip in much smoother and more responsive. Air fuel ratio out of the box not bad at all. That edelbrock out of the box setup, was piston burning lean.
https://www.holley.com/products/fuel...QaArfLEALw_wcB
Old 10-01-2019 | 12:50 PM
The quick fuel mutiny brought Holley into the 21st century. It’s a much improved mousetrap.
ph1971 is offline
Old 10-01-2019 | 01:06 PM
Yes, I am new to carb tuning but have done a Q-jet, a Weber using Edelbrock stuff, and now the Quickfuel. I find the Quickfuel easy to work on, but I know more now too. The silicone-like gaskets are key.
NHGuy is offline
