-   -   Running hot (https://www.offshoreonly.com/forums/do-yourself-boating-budget/362916-running-hot.html)
38fountained 09-12-2019 09:17 AM
Running hot
mercruiser 8.1 getting EMCT warning both manifolds. Due to Stainless Marine suggestion the hose between oil cooler and manifolds were deleted. Is this enough to cause low flow and overheat. Pumps all new, water pressure 15 psi at 3000rpm.https://cimg8.ibsrv.net/gimg/www.off...a031749d2c.png
AllDodge 09-12-2019 09:40 AM
Could use a serial number?
Your a little low on pressure
Get a piece of clear hose at the hardware store, double barbed fitting and couple clamps. Install the hose at the inlet side of the HX and take it for a run and look for bubbles. If there is bubbles you have an air leak
38fountained 09-12-2019 09:50 AM
Both engines running same 15 psi, leaks possible but no overheat on port engine with original hose connections. Engines both 2004 OW16——-
AllDodge 09-12-2019 10:15 AM
Good info to know all the info
Its either the cooling water system or the sensors. Figure your codes are 160 and 179
Could use an IR temp gun and compare temps at the sensor locations
Codes may be incorrect because you didn't say if your getting a constant alarm
38fountained 09-12-2019 10:51 AM
Getting weak horn, horn probably bad. Sensors new. Will get temp gun check. Were hot to touch last ride.
38fountained 09-12-2019 10:52 AM
Hose cut out is #14 on diagram.
AllDodge 09-12-2019 11:44 AM
That's just for draining during winterization. Would look a little closer if both had the same issue
38fountained 09-12-2019 12:07 PM
Just to clear hoses # 6 and # 14 leaving only main supply line for water to the exhaust manifolds on starboard engine, the one running hot. Port engine has original hoses and connections running normal. Starboard engine at idle was running and risers were just warm to the touch. Engines temps are balanced and normal.
