-   -   under hatch pictures turbo setups (https://www.offshoreonly.com/forums/do-yourself-boating-budget/366166-under-hatch-pictures-turbo-setups.html)
akattack 05-28-2020 08:27 AM
Not sure why Patrick (phughes69) hasn't replied so I'll answer for him. He is running waste gates to control the boost pressure. You have 2 choices, waste gates or drilling a hole in exhaust housing to bleed some of the exhaust out. Without either your boost pressure will be excessive. I tried it and giving the throttles a half throttle blip jumped the pressure to 15psi so in fear of doing damage I never gave it more throttle until I installed the waste gates. The original Mercruiser/Banks 475 package using RayJay turbos controlled pressure with a 3/4" diameter hole in the exhaust housing which yielded about 4 or 5psi.
Andy
brett fiddes 05-28-2020 09:00 AM
Andy
Thanks for the update
For the Rajay turbos that came with the Mercruiser/Banks 475 package, did they use the 1.0 A/R or 1.3 A/R turbine housings?
cheers
Brett
akattack 05-28-2020 10:12 AM
Brett,
I can't remember for sure (so long ago) but I believe they were 1.0. I believe the turbine A/R was marked inside the inlet. Patrick would have to look and confirm.
Andy
check300 05-28-2020 10:15 AM
Originally Posted by brett fiddes (Post 4740538)
check300
looks clean set up
are you running any waste gates on hot side?
I had some 12mm stainless adaptor place laser cut for the imco powerplus manifolds and have ordered 90 degree sch10 S/S elbows, I'll have a crack at fabricating the riser from exhaust manifolds to turbo, will use V-band clamp so can move turbo around to get in correct position. This will push the turbos approx. 8" back from there current on centre location,
Forgot had some aero race/imco /? double skinned water cooled pipes put away few years ago, so they would come off turbo, and get me close to inside of transom. At present from where turbo is mounted I have 1200mm (47") length to transom and pipes are 36" long
at least got the cooling issue covered
pic uploaded shortly
I ran 60 mm wastegates because my turbos were big and wanted to go to 50# of boost. I had adjustable boost with a key switch that allowed 12, 24 and 28 lbs of boost.
resurrected 05-28-2020 10:26 AM
This is a project of a friend of mine
23' Caravelle with Vw/Audi twin turbo V6 with Arneson drive
Had it wet a couple of times, struggling with the computer and ABS/traction control delete issues
Should be fun when the bugs are worked out
https://cimg5.ibsrv.net/gimg/www.off...8547b3fc54.jpg
phughes69 05-28-2020 01:15 PM
Originally Posted by CDShack (Post 4739004)
Phughes69--I'm doing a Gentry twin turbo/twin engine boat. I bought the set but there was NO instructions or diagrams. Where are you getting your water for the intercoolers? Some have said they have a forced water pickup and they only get water while underway, others have tied them to their raw water pump. What's your setup and are you happy with it?
The water is coming from a pair of Mercruiser transom mount water inlets. I have two hoses connected to each inlet because the intercooler has two separate heat exchangers.
phughes69 05-28-2020 01:23 PM
Originally Posted by brett fiddes (Post 4741086)
Andy
cheers
Brett
Like Andy said, the exhaust housings are 1.0 A/R. I spoke with a guy who was looking for the 1.3 A/R housings and the picture he sent me, the exhaust side was much wider. Aas far as boost goes. I adjusted the waste gates so I could get 15 psi of boost. It did not work well and I wrecked the center bearing in the turbo. I think at 15 psi the turbo is spinning too fast, which caused the bearing to fail. My next twin turbo setup, Im going to dial the turbos in for about 5psi of boost. When I build the turbo engines for my 377 Scarab, I'm going to put a speed pickup on the turbos so I know what they are actually spinning at.
brett fiddes 06-06-2020 07:06 PM
Check300
what size turbos, and brand are you running on the 572"?
I had a look on another post and looks like the wastegates are vented to water cooler exhaust before it exists through transom, is this correct or are they vented to atmosphere through the hatch vent?
The key setup on dial a boost is nice setup
Phughes69
are your waste gates vented to atmosphere under hatch?
check300 06-06-2020 08:54 PM
Originally Posted by brett fiddes (Post 4742401)
Check300
Phughes69
The waste gates do dump into the exhaust via a small pipe plumbed into the main exhaust. The turbos are 75mm. This combo made over 1700 hp at 25# of boost.
phughes69 06-06-2020 11:39 PM
Phughes69
On my 377 Scarab the wastegates dump into the thru prop exhaust inlets on the TRS transom assembly. On my 30' Scarab I think I'm going to have the wastgates dump back into the exhaust just after the turbo. My only concern will be how the turbulence may affect the O2's
