trim tab issue
trim tab goes up but not down. With both the dash switch and the trim tab switch on the throttle only hear a click at the pump but it doesn't run. Works fine for up with both switches. Other side is fine.
Its pretty simple to test... hop in the bilge with your handy test light and have someone push the switch...green wire is down blue wire is up, got power when you click the switch to the solenoid ? Does the solenoid throw power? are the grounds good???
