-   -   Carb issues???? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/367104-carb-issues.html)
flashgordon 06-24-2020 10:18 AM
Carb issues????
took boat out for run last week , after running 15-20 minutes at different rpms, the right motor just dies, try to restart cant get it to fire. so idle back across lake st.clair , get closer to launch , check to see if i am getting gas , and yes getting gas, try again , nothing , idle another ten minutes , try again this time open throttle 3/4 way and get the motor to fire. i think i have bad needle and seat???
or do msd 6a boxes act up????
carbs are 1050's , also notices around needle seat float .
also time before motor did same thing..
thanks..
SB 06-24-2020 10:37 AM
Sure sounds like a My Spark Died coil issue. Work when cold, die when hot. Inline spark testers like $15. My fav and found every part store in person and online. Lisle
https://cimg0.ibsrv.net/gimg/www.off...da40f1bed.jpeg
SB 06-24-2020 10:42 AM
Needle and seat issue can happen too. If it sticks open fuel will pour out of the bowl vent. If it sticks closed there will be no fuel in that half of carb.
Your description of your issue sounds more ignition related but I’m here behind a screen. :)
flashgordon 06-24-2020 11:31 AM
hmmmmm,,yea not sure,,,thinking motor was really flooded , as started with throttle also wide open
thought of swapping msd box from motor to motor..
thanks ..
and i will swap coils also..
Scarab28 06-24-2020 04:45 PM
Pull MSD Dist cap, They tend to rust up very quickly
flashgordon 06-26-2020 08:15 AM
hmmm ok thanks, was finishing up another project , but now back to scarab
thanks
SB 06-26-2020 08:34 AM
thanks ..
I thought you just had MSD coils, mot my spark died everything.
oconnor marine 06-26-2020 11:23 AM
thanks ..
FLOODED. I would say flooding. You can check by cranking motor attempting to start. Tgen stop. look into venturies and if you see gas dribbling in its bleeding off till the fuel pressure drops. Bleeding off due to needle not seating. Disassemble and clean carb.
ThisIsLivin 06-30-2020 08:44 AM
I had a coil fail and it did exactly the same thing. Had to wait for it to cool down so I could limp back to the harbor.
Batmeat 06-30-2020 05:52 PM
Id addition to what others have said, look at the accelerator jet and see if it's stuck open.
