-   -   EFI to Carb Harness Questions (https://www.offshoreonly.com/forums/do-yourself-boating-budget/367715-efi-carb-harness-questions.html)
Dutchboy 07-27-2020 10:28 PM
I'm plugging my harness back up and since everything is moved around. I really don't know where **** plugs up.
plus a couple plugs have broken. I have a new harness to make one but I'd like to get it running with this one first and then custom make the other. I have other pics of plugs just prefer to start here. So this is a red wire and a orange wire and also yellow/red stripe. I'm pretty sure the yellow red goes to signal on solenoid. I'm think orange red go to lug on starter that is constant 12v from battery correct? Just need to put a ring terminal on it?
https://cimg9.ibsrv.net/gimg/www.off...9fc95f088a.jpg
ThisIsLivin 07-28-2020 08:28 AM
On my 1998 the red is on the battery post on the starter and the yellow stripped wire is on the solenoid.
F-2 Speedy 07-28-2020 08:33 AM
yes, the orange is the charge lead coming from the alternator, red/orange on the big lug and striped wire to inside terminal of solenoid
Dutchboy 07-28-2020 01:38 PM
so the orange and red wire will have 12v constant even when the boat is off? My starter has a big red cable running directly to Battery so Im assuming those wires connect together.
F-2 Speedy 07-28-2020 01:39 PM
yes same lug
Dutchboy 07-28-2020 01:40 PM
thought I quoted you in reply above, sorry.
