Water in oil from gas?
SubscribeI was reverting with a 110° lsa on my big block. I know theres more to it than just the lsa but 109° is suspect in my shade tree mechanic eyes. The oil pressure is another issue so check with a mechanical gauge. It looks like a strong chance that its coming back out.
SB
close
- Join DateNov 2004
- LocationOn A Dirt Floor
Liked:3,708 Times in 1,693 Posts
Quote:
That cam is what comes in GM 96-2000 5.0/5.7 Vortec trucks.Originally Posted by Baja Rooster
I was reverting with a 110° lsa on my big block. I know there’s more to it than just the lsa but 109° is suspect in my shade tree mechanic eyes. The oil pressure is another issue so check with a mechanical gauge. It looks like a strong chance that it’s coming back out.
Does it even have any overlap at .050 " ? Doubt it. 196*/206* duration at .050" is tiny. LSA has to be looked at with duration #'s to come up with enough overlap at .050" lobe lift to cause reversion.
mike tkach
close
- Join DateOct 2007
- Locationyorkville,il
Liked:94 Times in 55 Posts
have you pressure checked the exhaust manifolds&risers?you may have something cracked.
Quote:
No, but I wish I did when I had the block at the machine shop. There are no visual rust trails other than this riser, the other is just black from exhaust.Originally Posted by mike tkach
I also did a compression test and expected to see a little higher numbers on a new motor. Is it possible I tightened the valves to tight?
SB
close
- Join DateNov 2004
Just for fun, had a few minutes, so I ran some #s.Originally Posted by SB
That cam is what comes in GM 96-2000 5.0/5.7 Vortec trucks.Does it even have any overlap at .050 " ? Doubt it. 196*/206* duration at .050" is tiny. LSA has to be looked at with duration #'s to come up with enough overlap at .050" lobe lift to cause reversion.
The above cam has -17* overlap at .050 .
A 209/213 at .050 with 114LSA cam has -17* overlap at .050 also.
Here are some popular performance cams :
A 218/224 at .050 with 112 LSA has -4* overlap at .050 .
A 226/232 at .050 with 112 LSA has +5* overlap at .050. With 114LSA it has +1* overlap at .050.
A 236 / 244 at .050 with 112 LSA has +*16 overlap at .050. With a 114LSA it has +12*. overlap
So basically reversion is a non issue with my motor?Originally Posted by SB
Just for fun, had a few minutes, so I ran some #s.The above cam has -17* overlap at .050 .
F-2 Speedy
close
- Join DateMay 2012
- LocationMidwest & T-Rock
Liked:3,967 Times in 1,808 Posts
what preload are you using, I presume hydro roller ?
Quote:
Yes hydraulic roller. I wiggled the push rod up and down while tightening until there was no movement left, then spun it with my fingers while tightening until I could not spin anymore. Once that was done I went a 1/2 turn more. Originally Posted by F-2 Speedy
With #1 at TDC I tightened exhaust 1,3,4,8 and intake 1,2,5,7
With #6 at TDC I tightened exhaust 2,5,6,7 and intake 3,4,6,8
F-2 Speedy
close
- Join DateMay 2012
what lifters are you using, on mine, when I feel tension or drag on the push rod I then start the preload to 3/4 to 7/8 turn down, you could be collapsing the plunger if you tighten till you cant spin the push rod, and might be hanging a valve openOriginally Posted by Ryanw10
Yes hydraulic roller. I wiggled the push rod up and down while tightening until there was no movement left, then spun it with my fingers while tightening until I could not spin anymore. Once that was done I went a 1/2 turn more.With #1 at TDC I tightened exhaust 1,3,4,8 and intake 1,2,5,7
