Bbc 454 gen 4 overhaul
Old 11-01-2020 | 04:47 PM
  #31
Default Build
Question when u run a blower shouldn't u change pistons to like 8 - 1 ratio
Baja 250es is offline
Old 11-01-2020 | 06:46 PM
  #32
Default Build
I can't find any good info stating a good blower build
Old 11-01-2020 | 06:54 PM
  #33
Default Build
Other than being bored .030 are these pistons direct replacement for stock pistons and should I do anything special to run these with a wieand 177 blower
Old 11-01-2020 | 07:04 PM
  #34
Originally Posted by Baja 250es
What do u mean by get the tune right ?
Generally speaking, it means getting ign timing and fuel mixture adjusted across all RPMs, load conditions and temperatures to achieve max power/best driveability while maintaining a degree of margin to prevent damage or accelerated wear.. Also includes adjustments for quick transitions from one power setting to another (similar to an accelerator pump on a carb), This is where the WB02 comes in handy.
Edit: Missed the part abt op using a carb. Either way, same principle.
zz28zz is offline
Old 11-01-2020 | 07:14 PM
  #35
Not really. It's all about building cylinder pressure. Starting with a little high compression ratio just means a little less boost to reach a give HP goal.
Smitty275 is offline
Old 11-01-2020 | 07:35 PM
  #36
Default Build
So if I bought a complete blower setup off a guy on here he had it on a stock gen 4 454 365hp and I rehoned, reringed, rebearing, new oil pump and resealed bottom end went through heads completely and bolted his stuff on i should be ok theoretically speaking
Old 11-02-2020 | 08:00 AM
  #37
Rookie's Avatar
Theoretically yes, but we don't deal in theoretics. It should be close. Tune it properly or don't do it. Also that engine has low-mid 8:1 ratio.
I believe you have the basic platform of the 525sc.
Rookie is offline
Old 11-02-2020 | 08:10 AM
  #38
Default Build
That's what I was trying to figure out if these pistons were a direct replacement for stock pistons if they were id say that blower setup will work just fine on my engine
Old 11-02-2020 | 10:16 PM
  #39
Stock compression on a 454mag/365hp is 8.75. You can run 5# of boost with no issues on 93 octane fuel.
Griff is offline
Old 11-03-2020 | 04:46 AM
  #40
Default Build
Ok cool thank u , Griff that's what I was looking for sorry to be a pain never built a blower motor rather be safe than sorry also what are the best head gaskets to use and any recommendations on valve springs im redoing the heads today and getting checked at machine shop
