Bbc 454 gen 4 overhaul
Old 11-08-2020 | 05:05 PM
  #61
Default Build
Or I should say id like to put another 700hrs on it myself
Baja 250es is offline
Old 11-08-2020 | 05:06 PM
  #62
Default Build
Mcollinstn its a 1050 holley carb but ignition is all stock
Old 11-08-2020 | 05:38 PM
  #63
Default Build
So is there not a good cam out there that I can install with out doing any machine work or is there no way around this
Old 11-08-2020 | 07:10 PM
  #64
You can use the Gen VI cam in your Mk IV. Just need to get the retainer plate thru GM. The block "should" already be machined for it. I'd be surprised if it isn't already. Use the Gen VI chain set.
Smitty275 is offline
Old 11-08-2020 | 07:21 PM
  #65
Default Build
Old 11-08-2020 | 07:22 PM
  #66
Default Build
Old 11-08-2020 | 07:23 PM
  #67
Default Build
Old 11-08-2020 | 07:36 PM
  #68
http://www.summitracing.com/parts/na...1053/overview/
That's the link to the GM chain set and includes the retainer plate. Some have said they needed to elongate one of the bolt holes in the plate to use it on the MK4. Some will complain it's a single roller but it's plenty strong and durable.
Old 11-08-2020 | 07:46 PM
  #69
Default Build
So there isn't a direct replacement performance cam for this engine
Old 11-08-2020 | 07:49 PM
  #70
Default Build
or is this my easiest option for a mark 4
