Water Pressure Gauge quesiton
Thanks!
The plug on the thermostat housing should be 1/4 NPT.
The items in your pic should work just from visual. The 1/4 to 1/8 NPT bushing should be the same
Agree the water pump plug is for lube for the fuel pump cam
Thanks all...plug in thermostat has been removed and is different size from Gaffrig adapter...will get the right connector and hook it up...THANKS for bearing with this novice. My goal is to "do no harm" to my set-up while I learn.
Tom
Tom
Coming from the thermostat housing, the gauges barely move off the peg at idle on the garden hose. If I bump the throttles up to about 1200-1500 rpms I see a slight positive gauge movement (1-2 psi)...is this normal (Hardin raw water pumps on big blocks)?
Please post up your readings when you get out on the water. I have a pressure gauge mounted in the same location and don't seem to get the readings (only around 5-6 psi around 3-4k RPM) everyone else does. But I also found out my thermostat was missing too.(bought a used engine)
You were exactly right...ACE Hardware is the place!
