Stock L29 rebuild question
I pulled the 98 L29 454 out of my Sea Ray cruiser to put a new transom assembly in and decided to rebuild the motor. I had the block cleaned, line bored, cam bearings replaced etc. The heads I just disassembled and had cleaned and the valves refaced. I'll lap them. I'm going to machine the heads for posilocks myself.
My question is about rotator eliminators. I'm running everything stock because it's just a cruiser, but I want to install eliminators. Can I just replace the rotators, set the spring height and call it a day? I can cut the spring pocket myself also. I don't have to put in new springs and locks or anything else do I?
Thanks.
Thanks.
Are we talking about the same thing? There are a million different spring combinations out there. When I did this for my 69 Camaro, I installed the springs Lunati recommended for the cam I was using. I then set the spring heights using the eliminators that I bought as a set. It wasn't a "kit."
The eliminators sold by comp are 0.300" which is about the same height as the stock rotators. They should drop right in place of the stock rotators, but you may need to clearance the inner hole a bit if you want a nice slip fit, I did recently.
If you want some cheap power you might want to clean up the bowl area in the intake port and clean up the exhaust slightly on those heads while they're apart, and if you're cutting the guides for seals already why not throw a cam and a set of dual springs in. That's just what I would do since I can't leave something alone though
