Ignition module trick
Old 03-04-2021 | 08:19 PM
Default Ignition module trick
Has anyone ever heard of using a 4.3l merc ignition module on a gen 4 454 in place of its own v8 ignition module I was told it was an upgrade can anyone confirm or deny this
Baja 250es is offline
Old 03-04-2021 | 08:28 PM
SB
Yes. A ton of people here over the years. Since it has very little advance when used on a v8, mostly people with roots supercharges and those with very large cams naturally aspirated use them as it lets you put in a lot if initial advance.
SB is offline
Old 03-04-2021 | 08:33 PM
SB
Here is a good post from Griff on it and others. Includes the advance curve charts.
mercruiser ignition module question
SB is offline
Old 03-04-2021 | 09:09 PM
Default Ignition
I'm building a .30 454 500hp cam roller setup with a wieand 177 on it I guess it would benefit me
