motors running way too fat, >
Old 05-05-2021, 10:58 PM
Received 4,353 Likes on 1,247 Posts
You add powervalves it`s just going to make it richer.
ICDEDPPL is offline
Old 05-05-2021, 10:59 PM
Originally Posted by fbc25el
Are there little brass tubes sticking out in side of the throttle bores ? Also the three little holes on top by the vent tubes is one of them blocked off ?
these holes???
flashgordon is offline
Old 05-06-2021, 03:33 AM
Are both carburetor setup the same? PV and jetting? If not.....
The fuel mixture looks too rich. Reduce the jetting size or increase the power valve to
a higher factor to prevent it from opening too soon.
Also, look for leaking needle and seat in carb and excessive fuel pressure.
AmiableDave is offline
Old 05-06-2021, 06:06 AM
They list as 3 circuit 1050 cfm. 3 circuit do not work well in a boat app. You can convert them to 2 circuit but I don't know how much you want to git in to.
fbc25el is offline
Griff (05-06-2021)
Old 05-06-2021, 06:22 AM
Originally Posted by flashgordon
i dont know if this helps,,,stamped on top side of carb....
You have Holley 9375's.. the faint stamping below the "9375" ( as though you were reading it right side up) is the date code
https://www.holley.com/products/fuel...parts/0-9375-1
speicher lane is offline
Old 05-06-2021, 08:44 AM
SB
Received 3,130 Likes on 1,408 Posts
Decent thread, for those that Atleast semi understand carbs, on the older list 9375’s (prob the OP’s carb) .
https://www.speed-talk.com/forum/vie...php?f=1&t=9934
SB is offline
Old 05-06-2021, 11:17 AM
hello dave,,i beleive both carbs are set up same,,guess i will add to list to check....
both motors run tooooo fat...everything on motors are same ..msd..cams ..etc...
and the PV are blocked...
so i guess i need to see what my vacum is at idle and base PV from that ...correct???
thanks for advice.........also want to get a wideband o2 senor set up.....but O2 senors can not get wet correct????
no sure where i can mount it...
thanks again
Old 05-06-2021, 11:19 AM
how do i change to a 2 circuit???
thanks for advice
Old 05-06-2021, 11:26 AM
are you running stainless tails ? hard to see in the pic, if so you can have bungs welded into them, moving to a #7 might help
hello speedy,,,,,the O2 sensor can not get wet , correct???
not sure if i can do that with my extension pipes,,,as they are wet.....
i guess ,,i could make them dry dump water out another way ,,,but would the exhaust extensions and tail pieces in transom get to hot????
unless i make new extension pipes and make them like headers...double walled...that would be a fun welding challenge
thanks for advice
Old 05-06-2021, 11:37 AM
F-2 Speedy's Avatar
Received 3,075 Likes on 1,361 Posts
thanks for advice
no it cant get wet, if your tail pipes are not jacketed you cant add bungs in them
F-2 Speedy is offline
