Transom water dump help
My boat has a 1.5 hole in the back of it where a water dump used to be, the PO took the fitting and I’m having a hell of a time finding one.
it doesn’t have to be anything special because I’m going to cap it off anyways. I just need to fill this large hole in the transom. I’d like to leave it fitting and not fill it in. it needs to fit in a 1.5 hole and be longer than 2” the PO removed some of the transom just to make the fitting he had fit. https://cimg2.ibsrv.net/gimg/www.off...54de32112.jpeg https://cimg3.ibsrv.net/gimg/www.off...c473ba266.jpeg |
That’s the problem is none of those fittings use a 1.5 hole and are over 2” of threads.
Do you think a 1/4 of flange on the outside will be enough? I will make sure to 4200 the **** out of it. |
An 1/8" plate of stainless, weld a short section of stainless allthread and a little bar to tighten it against. Seal the whole mess off ,you can make it any size you want .
Thickened/reinforced epoxy and a little gel
Just install this using 3M 4200. You won't need the threaded portion. It won't move once installed.
https://www.cpperformance.com/p-1380...ting-long.aspx |
| All times are GMT -5. The time now is 11:33 PM. |
