Lower unit info ??????
Old 06-28-2021 | 06:09 PM
Default Lower unit info ??????
Stock bravo 1 lower
Imco -2\" shorty lower
ok I'm trying to install this imco lower on my bravo 1 upper and I have this oil hole (small white o ring) on my lower and not on my upper and if u notice above the stock lower does not have it so wtf should I do did I buy the wrong lower am I screwed any help would be appreciated
Baja 250es is offline
Old 06-28-2021 | 08:43 PM
You have an old upper, you need to plug that hole in the lower with a Welch plug
Unlimited jd is offline
Old 06-28-2021 | 08:49 PM
Default Lower
Won't that starve the lower from oil supply
Old 06-29-2021 | 09:11 AM
It will still get oil the same as the stock lower did
snapmorgan is offline
Old 06-29-2021 | 09:19 AM
Default Lower
What is the purpose of that hole ?? Just better circulation
Old 06-29-2021 | 09:27 AM
Correct, just tap it out to 5/16 and screw a set screw in it
