power valve
Old 07-30-2021 | 12:24 PM
Originally Posted by flashgordon
wow........alot of info...but i like it...
so do u run the daytona sensor system with your msd distributor????
so u replaced the msd box with the daytona system??
what motor and how big is cam??
thanks for info........
Yes, I have the Daytona Sensors box connected to my MSD distributor. I did replace the MSD box with the Daytona sensors, so much better. I have a 524ci BBC with AFR 305 ported heads. The cam is a custom Comp with .623"/.612 lift and 242/252 @ .050" duration with 112 degree lobe separation.
Patrick at Pro Systems is someone I would call to modify your carbs. He will wet flow them as well.
ThisIsLivin is offline
Old 07-30-2021 | 01:01 PM
Talking
ahhh thanks for info,,,i would be willing to send my carbs to someone to go thru them.
i called tyler crockett about going thru carbs,,they said buy new ones...ok thanks for help...
i am litttle bigger..547,,389cc runners,,,720 lift isky....maybe i shoud be using bigger carb...
thanks for advice,,,,going to call pro system....
someone else suggested nickerson carbs..guess they did his guys carbs..
again thanks
flashgordon is offline
