Alarm
Old 08-02-2021 | 12:47 PM
bigboat28's Avatar
Default Alarm
Mefi3, alarm sound at over 2000rpm, 1 beep every 3 second, and goes off till you slow back down, all gauges normal and gear lube is full. Any ideas?
bigboat28 is offline
Old 08-02-2021 | 12:48 PM
bigboat28's Avatar
And no codes when scanned.
Old 08-02-2021 | 07:56 PM
Pull a wire off each alarm sender one at a time. The alarm sender wires are tan with a blue stripe. Start with a drive lube sender wire.
Griff is offline
Old 08-03-2021 | 07:25 AM
Don't know what motor, but if it has a fuel pressure sensor (L29 or 350 mag) it could be a soft alarm
AllDodge is offline
Old 08-25-2021 | 09:41 AM
When mine does that it’s the water pressure sender/sensor
Nassauk is offline
