Engine cooling/thermostat question... >
Old 10-14-2021 | 03:43 PM
TomZ's Avatar
Originally Posted by AllDodge
Its weight that had me place on the shelf. To change the impeller I have to hang upside down, there is no room. The added weight just makes it to hard for this old guy.
That's why I got rid of the whole thing.
TomZ is offline
Old 10-14-2021 | 08:16 PM
Originally Posted by shunter2005
I agree with Griff. Check the oil cooler inlet first. Take both hoses off and check with a flashlight from the bottom up to see if there is debris blocking the capillary tubes. If there is debris, clear it and see what the debris is. If it's rubber impeller vane pieces, you will know. I found a complete vane in mine after a shop "allegedly" flushed all the hoses.
Most times on the hose, the temp will be close to normal, at least mine does. Curious, but what temp t-stat are you running? I run 160* in mine and the motor runs between 170-175. 180* isn't hot by any means. Personally, I like a little heat in the motor.
Unfortunately, I am not looking at my boat right now as I am on my way back to North Carolina. I have a picture of my port engine (the one that has the higher temps) and (I believe) this is the oil cooler, right?
I am running 140F thermostats and I consistently see no more more than 150-155F water temp although my oil temps spike 180-190F when I am doing a speed run.
Ps-I did NOT note any increase in oil temperature when I was idling around and my water temp started to rise???
F14A water jet is offline
Old 10-14-2021 | 10:15 PM
TomZ's Avatar
That’s your oil cooler.
TomZ is offline
Old 10-14-2021 | 11:24 PM
SABER28's Avatar
that seems like a really small oil cooler to me. maybe not your problem but if you are making 500 plus hp this is the size i run.
SABER28 is offline
Old 10-15-2021 | 08:27 AM
TomZ's Avatar
We have similar to Tom’s on the Bullet and never an issue.
Mine are similar to SABER28’s with exception of thermostat rails.
TomZ is offline
Old 10-16-2021 | 07:56 AM
Thanks all...engines are built by a pro and I do see about 190F after a solid speed run but water temps are always in range (except as noted this time).
I can see that this is going to require some contortion to get back there. I wonder if I can snake a remote camera down the water hose for an inspection?
Old 10-16-2021 | 11:42 AM
TomZ's Avatar
Before getting too deep into it. Take her out again to see if the condition is still there. Something may have been blocking the intake.
Over the winter… add some water pressure gauges to the system. They’re important to have and will alert you to problems before they become a big thing.
TomZ is offline
Old 10-16-2021 | 12:43 PM
I was thinking about doing both (re-run and gauges)...winter is short down in Pensacola :-)
Old 10-16-2021 | 12:53 PM
That is your oil cooler that you circled. All you need to is pull off the water hose and feel inside the end of the oil cooler with your fingers for any debris. It is only about a 2-3" deep before you will touch the front plate with the cooling tubes.
Griff is offline
Old 10-17-2021 | 08:39 AM
Will do!
Can somebody recommend an analog water pressure (or flow) gauge to put inline in my set-up?
