Wierd shore cord issue, HELP!! >
Old 12-03-2021 | 02:33 PM
I,m still confused. Maybe I missed it. Can you please let us know what the simple fix is, by posting it here, again.
350scarab is offline
Old 12-03-2021 | 05:08 PM
Disconnect the Promariner system or the Galvanic Isolators, Plug the boat in..EZ test. Install latest system thats compatible with GFI dock power.
fossil fuel is offline
Old 12-05-2021 | 10:59 PM
Thanks everyone,
If you ever have something like this happen, Unplug everything in the boat 1ST!! (It changed the symptoms I was getting).. For my boat, both Shore cord 1 & 2 neutrals were put on the same bus bar in the Main panel on the boat. I removed the 2 neutrals from the buss bar that go to the SC2 sub panel and bonded them together to incoming SC2 neutral with a wire nut in the main panel and BINGO.. Everything's working well. I turned on everything in the boat for the 1st time since I bought it.. The grounds are bonded but not the neutrals...
2Cheap4Society is offline
